1 - 8 of 8 Posts
Discussion Starter #1
Hoping for advice/direction here, comments appreciated. '05 Laramie with working remote key fob and one working ignition key- I have an uncut chipped & unprogrammed key blank. What's the most cost effective way to have it cut and programmed so that it's useful? Thanks in advance! Tim
As far as I know, only the dealer has the 4 digit code to program the key.
Discussion Starter #5
Thanks!
I appreciate your post. The truck actually belongs to my youngest (age 27) son, & when he got it, there was only one key. Tim
My 05 slt didn't use a transponder key it was just a standard y159 or Access+19R2 blank if key head is black its not transponder only grey key heads are
Premium Member
For those people that need a key, check out IKEYLESS
if you don't see your particular key or FOB, call them
I found out for my 2009 Ram 1500 SLT QC
the dealership is expensive most times
They do make 2 different FOBs for mine, one reads Dodge on the FOB & the other reads RAM, they are identical in every way, except for the lettering
The Dodge one does not cost as much
1 - 8 of 8 Posts
