1 - 1 of 1 Posts
Well I don't know if I should put this in the 5.7 or 6.4 as I have a 5.7 hemi stroker I have built. However that is the issue, it will start on the first start attempt but it is super rough won't idle for long before dying and this is after the tuner has played with fueling and everything to try and get it to run correctly. He says the fueling changes he is making are not doing anything in the logs I have checked everything compression comes out good, timing is perfect and the spark plugs are cleaned and good we have tried 2 different fuel injectors nothing is working.
Any help is appreciated thank you..
1 - 1 of 1 Posts
