1 - 9 of 9 Posts
What's up guys I got a hold of some hids from a buddy of mine that never put'em in his truck, he said he needed more shit to make them work & didn't wanna fool wit it so he sold'em to me for $50, got a pair of H1s,H10s & there from hidextra an never been open, he had some specd aftermarket headlights & said they would fit my spyders but I needed some capasitors & relays for the H1s to work & fogs should work just plug & play, so I hooked up the H10s in fogs earlier they worked fine when key was on the on position but then cranked truck & they were flickering & went off, so can someone plz tell me what all I need to make both sets work properly, looks like it's just bulbs, cords,& ballest that came in box, I have a 2014 ram 2500, this is the 1st time i've ever messed with hids, thanks
2 different ways to make them work. The easiest is to get some anti flicker modules, they are plug and play and will cure the flicker and bulb out issues. They can be found on the web for as low as 7 bucks a module and are compatible with pretty much all the HID kits. The other way is to install the kits with relay harnesses. This is a more indepth solution but will also cure the flicker issues. Hit up retro source for these.
Discussion Starter · #5 ·
Thanks stump, do I need a capasitor and relay for each H1 bulb for lows, I was gonna call hidextra Tuesday sense they came from them to see what they had I'll ask about the anti flicker mod
If you're going the relay route, one harness will fire 2 bulbs. So you will run your lows on one harness and your fogs on another. If you go anti flicker modules you need one for each ballast so a total of 4.
These should work for you.... http://www.hidextra.com/capacitor/
I have CanBus ballast hid's on my peojectors but just some $15 ddm error cancelers on my fogs and has a set on my 09 low beams. They worked great and are cheap. Plug it in between and done.
Discussion Starter · #9 ·
this worked out great got'em installed huge difference, I called hidextra told them the issue I was having an they sent 4 capasitors an two relays free of charge that was awesome
1 - 9 of 9 Posts
