1 - 2 of 2 Posts
2012 Dodge Ram 1500 Hemi ok so here is my problem few months back was having problem with my radio cutting in and out I took it to dealer they said it was a bad radio ground they fixed the issue few weeks later the same problem had started am/fm and on aux now too so now that my warranty is no good I have to fix it my self !! Anyone know where I can locate the ground wire ? Let me know thanks !
Read Only
The issue may not be with the ground wirebut may be because something is causing a ground. The radio can use a chassis ground and may not have a dedicated ground wire -I haven't opened up a newer model Ram.
Check the harness...It's possible somewhere along its route it passes through a hole with no grommet - that can cause intermittent grounds. It can be as simple as a loose molex connector or solder/crimp IN the molex connector. Vehicle electric is a pain in the ass....
You can often narrow down the conductor causing the issue, but sometimes locating the origin is difficult.
Good luck.
1 - 2 of 2 Posts
