1 - 3 of 3 Posts
what do i need to do all up front lights to hid? :4-dontknow:
Well if you want to do all 3 lights (lows, highs and fogs) you would need a lot of parts. 2 common routes are either canbus ballasts (canbus harnesses) or wiring harness. Wouldn't recommend high beams with anything except halogen or LED since they are instant on with no warm up time. Retro fit source (TRS) or Retro shop dot us (Jeremy) are your best bet on what you need. For each headlight setup you will need 2 HID bulbs (select color), 2 ballasts. The rest of the parts depend on which path you choose to take. Goodluck!
I use the canbus ballasts on the lows in my 13 crew and now my 14's projectors and never had an issue. They are more expensive. For the fogs I used a cheap set of hid ballasts I had laying around from one of my other cars I sold and just got a set of error cancel boxes from DDM but there are a lot of places that sell them. Saved me some cash instead of using can bus on the fogs. They don't seem to be as sensitive as the headlights.
1 - 3 of 3 Posts
