1 - 4 of 4 Posts
I installed hids today everything is fine except the left one is angled higher than the right. does anyone know what would cause this and how to fix it?
Try taking it out and flipping it over if possible??!?!?!??! if this isn't the case then U may have to adjust it manually via the screw on the headlight. that's all the info i have man, good luck to ya!
Check your PMs
The light output from our housings suck so bad that when you add HIDs and get good light out of them the difference is just that much more noticable. A lot of people have had to re aim their headlights once they get HIDs. Its better to raise the low one instead of lower the high one otherwise youll have them both pointing basically at the ground
how do you adjust them , raise them i mean?
1 - 4 of 4 Posts
