I have an 06 Ram with aftermarket ANZO U-Bar projector headlights, I tried putting HID bulbs in but the CANBUS system just will not let them work like they should, ive went from A-Z with resistors and capacitors to try and get them to work through my headlight harness but CANBUS just keeps ****ing them up. The only thing i can think of is to wire my HID's straight to my battery and then to a toggle switch (ON/OFF) (of course with a relay and fuse) . Dont worry about high beams because they are an H7 bulb, the high beam flapper inside the housing still works without a bulb in the harness. All im wondering is if I wire it to an ON/OFF like I said, and just put the bulb in the housing and turn them on when i want them on, is it safe/will it work?
