what do you meen by caps? (is it capacitor)I've had pretty good luck with HIDeXtra.com. Get the relay harness for the lows as well as a capacitor harness (fogs are plug-n-play). I needed the caps for my '11 but didn't for the '09 I had before (same exact lights/ballasts).
Sorry - "caps" = Capacitorswhat do you meen by caps? (is it capacitor)
also i have the same kit as your, did you re-aligne anything or re adjuste the lights??
i have no problem, but some guys on this forum with other kits says to re aligne the lights???
okay thanksSorry - "caps" = Capacitors
No, I didn't re-align anything (got lucky with the factory alignment) but I did check the alignment (of the lights). Park about 25-30 feet in front of your garage door or a large wall with your lights on. Measure from the ground to the top of the headlamp (at your bumper). Now measure from the ground to the top of the light beam (cut-off line) on the wall. You want the second measurement to be about 2-3" less than what is measured @ the truck.
Agreed! Retro Solutions for sure!!retro solutions hands down bud
