I am wondering what the most common causes for this indication are. I have little history of this truck. My first thought is the cooling system. I replaced the engine radiator along with new water pump and all related hoses. The truck was not under heavy load when the light lit. My big question is; " Can old fluid and blocked filters cause "Hot Transmission?" This truck has logged over 170K. There is no temp tranny gauge. The engine temp was normal and the tranny shifts normally. I plan on dropping the pan and replacing the filter(s) and would like to know if while I am in there if you recommend looking for anything that might need adjusting or cleaning as a probable cause. This is a gas 5.9. Thanks Dan.
