1 - 2 of 2 Posts
ok i got a 96 1500 ram single cab and i want lower it but i dont want to cut the bed out or anything like that. so how low can i go :smiley_thumbs_up:
If it's a 2wd, then I've seen 4/6 kits for that generation. Probably the lowest you will find without going to a bagged setup and needing to tub the bed and front inner fenders. With a 4/6 kit you will have to be aware of your tire width in the front as anything over 9.5" will most likely rub.
1 - 2 of 2 Posts
