1 - 6 of 6 Posts
Hi - 2014 Laramie Longhorn
Manual says vehicles with EVIC will have this as an option to switch on or off (our has EVIC... does not have the option to switch on or off "sound horn with lock" ... it has all the other options (flash lights with lock etc.) but not horn
There is a procedure in the manual (hold lock for four seconds, press panic button, release together) for vehicles without EVIC
This doesn't work.
Horn still chirps. Frustration building ... This is going to end up "take to dealer and pay them to use their computer" isn't it...
Does anyone any bright ideas?!?
I did this the other day, it's a quick change in the settings menu...
edit - sorry just re-read your post....guess you checked and don't have that option in settings menu. maybe a firmware upgrade is needed?
He is across the pond, likely a different set of rules. I know in Europe for example, you can't get remote start from the factory.
Discussion Starter · #4 ·
... What the manual does not say is ... "press the unlock button for four seconds then the panic button..." .... which will turn the chirp off.
We are across the pond - but Longhorn is only available Canada or USA ... this one's from Canada
2019, Ram 1500, Limited
Cool where did u learn that. Can it be turned back on from the unconnect setting screen after if u want?
1 - 6 of 6 Posts
