1 - 4 of 4 Posts
Discussion Starter #1
I have a 2004 dodge Durango it won't idle. As long as I keep it idle up it stays running. When I let off the gas it dies
Throttle body electrical components wear out around 100k, are not serviceable or cleanable. These are the actuator
valve, throttle position sensor, throttle plate motor, all in the black box on the TB houseing. See this:
Bills86e
I have a 2002 dodge 2500 v10 it won’t shift out of first until I let up or go easy any udeas
I had a similar issue with my 2002 1500 with the 5.9. It would shift ok driving normal but if you took off and held it to the floor it would bounce off the rev limiter and not shift until you let off. After lots of research I replaced the governor pressure solenoid and that fixed my issue. Was a pretty easy fix, just drop the transmission pan and its held in by a plate and a couple bolts if I remember right. Just make sure when u put the new solenoid in in you feel it pop into place. If its not up in all the way your truck won't move at all.
1 - 4 of 4 Posts
