1 - 6 of 6 Posts
Here is a pic of the radio that's in my truck. However it is not the one that is supposed to be in there. I can tell because the dash has been trimmed to make it fit, the display is the only light that works on the radio and the front speakers don't work. My truck is a 01 Ram and what I would like to find if possible is some wiring input so I can get the rest of the radio lights to work and get the front speakers working as well. I would appreciate any and all help. Thanks
No problem below is color coding for the truck side
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Discussion Starter · #6 ·
Well I discovered today that one issue with the radio is both front speakers are shot. Strange unusual but, that's why they don't work (I checked the connections with just some small cheap speakers I keep around and they worked but not the factory speakers). Also got the dremel out and trimmed the radio face down so that the dash bezel would fit correctly.
1 - 6 of 6 Posts
