OK so I'm in Southern California and it the 1st of August, Its hot.
My 04 Quad cab with 152k and the Hemi has great A\C one day the fan blows hard and the next morning it doesn't blow at all. Now when I got the truck at 100K the only weird thing was a wire was jumped from under the glove box on the passenger side to a switched electrical under the driver side. The wire on the Passenger side under the glove box is pretty large and it's blue with a yellow stripe. Way back when the crimp on connector had burned and the fan stopped working, so I put on a new crimp on,right? When the fan stopped this time its the first place a went. I found a burned up crimp on and I decided to fix it right this time. I ran a big fat # 12 from the fuse box to the firewall on the drivers side and to the glove box on the passenger side. Soldiered and shrink rapped the connectors and I put a nice spade clip on the fuse box side and hooked that end to a relay for the rear window defroster. ( I don't have a defrost in the rear window) The fan comes on but now the damnedest thing is happening.
The air blows cold but the light on the AC button doesn't light.
The Speedometer doesn't work
It thinks its 72 degrees outside all of the time. Its Not!
I have a Break light on the dash like iI have left the Parking break on,( its not)
I have an ABS light on
Also, I might be crazy but it doesn't seem to be running right.
So I take the negative battery cable off for about 3 hours. I hook the cable back on nice and tight and on a clean post and start the truck up.
Guess what I got????
The speedometer doesn't work
It thinks its 72 degrees outside all of the time. Its still not!
I have a Break light on the dash like I have left the Parking break on,( its not)
I'm scratching my head,
Any Ideas??
Joe
Any Ideas??
Joe
