1 - 17 of 17 Posts
Super Moderator
19 Ram 1500 Big Horn Sport 5.7 Hemi 4X4 QC
Welcome to Ramforumz! I moved your post to another area where more members will see it. I also EDITED the title of your post as it violated the forum rules. Enjoy the forum!
Either find a good used set or preferably get new ones either OEM (pricey) or aftermarket but don't consider bandaids. You'll have a significant portion of the cost of replacements and the problem will still be there.
2014 345ci 8hp70 44-44 3.92 Truetrac NX Express Comp Greene Racing
Must be a southern truck, frame looks great but time for new leaf spring assemblies.
Absorbers should be done as well
What year and model of truck? Are you the original owner? Do you haul heavy items on a regular basis? Looks like heavy loads were put into that truck. If not you, then you can replace the leafs and mounts and rubber pads. I have seen the threads posted here. Lots of good companies out there.
On another note, if you consistently haul heavy things or tow heavy, upgrade your truck. Otherwise you are just wasting money.
Kenny
1998 Dodge 3500/GaleBanks maxed out.
2015 Dodge 3500/Stock/Traveling truck
1 - 17 of 17 Posts
