So now that i saw what Ford has done to add an integrated tailgate step, i started searching for something similar for my ram and found "The Livingstep" tailgate step.
https://www.tailgatestep.com/pictures
You get 2 options. The Surface mount or the drop in.
Surface mount is easy but looks like an add on the one im leaning to is the drop in because after install, it looks flush when not in use and works well when folded out. PLUS it has a 500 lb capacity. It does require some cutting into tailgate and soldering, but looks easy enough.
Check out the link? What do you guys think?
Only concern would be that after install, the tailgate may fill up with water because of the cuts that were made to accommodate the drop in of the step trough... see vids, pics and install instructions to see what I mean.
Other than that, it looks great.
