Well got my interior LED's sorted out thanks to the great advice of SS4Luck:smileup: and mikeski:smileup:. Had the problem of them flashing when the key was off and you turned them on by pushing the lens cover. Soldered the 1 watt, 100 ohm resistors to the contacts. Worked like a charm.
Also did the Reverse lights with WLED-CWHP15. Much brighter than the 921-CW12 as the bulb is making use of the reflector not like the 921 where the LED's are pointing to the top of the fixture.
Put the 921-CW12 in the Licence plate. I think there bright enough for the plate. Still have to do the high mount brake and cargo lights. Will get to it eventually.
Sorry about the picture quality. Took the pic's with the iPhone. Not that great.
http://i1110.photobucket.com/albums/h443/dexter5042/IMG_0101.jpg
http://i1110.photobucket.com/albums/h443/dexter5042/IMG_0102.jpg
http://i1110.photobucket.com/albums/h443/dexter5042/IMG_0105.jpg
http://i1110.photobucket.com/albums/h443/dexter5042/IMG_0107.jpg
http://i1110.photobucket.com/albums/h443/dexter5042/IMG_0104.jpg
