1 - 5 of 5 Posts
Discussion Starter #1
When towing my Travel Trailer, the inverter will not funtion. Has this happened to anyone else? Light use, trying to charge handheld radio while driving.
If it works when not towing, I can not see a connection. Are you using the factory wiring plug for the trailer? Do you have trailer brakes? Are you still under warranty?
Discussion Starter #3
Inverter functions perfectly when not towing. Factory wiring, under warranty. I am suspecting the electric brakes and the system will charge the trailer house battery while driving may put a bit of a strain on the alt. trying to use the inverter. May be a "safety" so too many amps are not drawn through the system.
I have the same issue. Was towing my travel trailer and could not charge my daughters DVD player. I also cannot run my electric shaver off the inverter...(sounds funny, but i shave in the truck on the way to work when i sleep in!LOL)...but the inverter in my old '07 Caliber R/T would run it no prob. I think it is just a weak sh*tty inverter.
Discussion Starter #5
Inverter
Inverter works fine w/o towing. That's is why I think the system is "smart enough" to know when there is an extra load on the electrical system. Who knows, but not a major problem - yet.
1 - 5 of 5 Posts
