1 - 4 of 4 Posts
Discussion Starter #1
I have a 2004 Ram that looses door locks, interior lights, radio clock with key off. The radio works sometimes and other times it doesn't. The iod fuse is not blown. I tried to look for shorted wires in dash and checked for loose or broken grounds but couldn't find any. please help!!!
Discussion Starter #2
I was sitting in the truck trying to look up info on my phone and the iod circuit would come on. Radio clock , lights, door buzzers all would work for a few seconds then cut out again for about 10 seconds then back on again for 10 or so seconds then off again and so on until I pulled the neg battery terminal. Now it seems to stay off with key out but fuse is not blown.
same issue
My issue is similar, everything works but but I'm getting codes that say they don't. I haven't had a chance to run any test yet. These are the dtc's that I get all at once b1648 b1644 b1638 p0073 b165e b162c b1633 b1661 c2206 c2202 u0164 and u0100.
Similar issue.
I'm dealing with a similar electrical issue. My 2007 5.9 is throwing these codes: P2149, C2100, C2200, C2202, C2206, C1079, B2305, B1661. The truck will occasionally start pathetically- missing and sounding terrible. After a minute or so, it runs fine. Other times, it will act up while I am driving (no power, missing, wheezing, etc.). I have already changed the valve cover gasket (and the wires to the injectors). I've cleared the codes and they return. I'm not sure what I'll check next. Please post your solution as it might be similar to mine.
Thanks.
1 - 4 of 4 Posts
