1 - 5 of 5 Posts
So I had a local shop install a hellwig rear sway bar and it seems too close to the track bar. I had the Mcgaughy 2/4 drop kit previously installed at the same shop. Well once I got there they asked where the end links were. I was unaware the sway bar didn't come with them. So I called Matt over at Moe's Performance, where I purchased the sway bar and he made me aware that the Mcgaughy kit should have come with the links. Well the shop found links from the original kit or I at least hope it was them and started installing the bar. They could only attach the bar on the out most setting since any farther in and it seems to hit the track bar. I actually saw them put it on the other way and it was even closer so I figure that's the only way it could go on. Has anyone else seen this?
As long as it missed and never hits or rattles, I think you're fine. I have one on my 05 and I like the added anti roll it gives, especially towing. I had to re-do my Borla dual exhaust to clear mine.
Looks wrong to me. Here is what mine looks like with the BT pan hard relo bracket installed and the Hellwig bar. Seems like your end links are incorrect and causing the bar to rotate up and closer to the axle...hard to tell because the pics are pretty bad.
Discussion Starter · #5 ·
thanks
Hi thanks for those who responded and sorry for the bad pics. Mine does actually look like yours Frank so I guess it's right. I've been driving it around for a week or so and it doesn't hit on the track bar.
1 - 5 of 5 Posts
