1 - 4 of 4 Posts
I recently bought a 2012 Ram 1500 Big Horn 4x4 Crew Cab with 5.7 Hemi. The factory tires are P275/60R20. Since I tow a Travel Trailer, I am considering replacing them with LT275/65R20 tires. Has anyone done this? Will they fit Ok? Any brand recommendations?
It will change your speedo.. you will be going faster then your speedo says you are don't know if that makes a difference to you or not.. Goodyear has the Wrangler in that size as does BFG...
I'm pretty sure they will fit with no suspension alteration, I'm doing the exact same thing. I'm gonna see if they fit at stock height and if now I'll level but I'm almost 100% sure they will fit there only a hair over an inch taller which means 1/2 inch closer to the wheel well and there is more room then that in the wheel well
1 - 4 of 4 Posts
