1 - 12 of 12 Posts
will installing a K&N cold air intake affect any of the computer programs ?
2011 ram 1500 laramie 4x4 5.7 liter hemi
I believe that you should be fine as they recommend when you do the install you have to disconnect the battery. In my understanding once you do that and reconnect it afterword the computer starts to realize the difference. Feel free to chime in as im not 100% certain.
It has no effect also easy to install it does tell you in the instructions to disconnect from battery. It took about 45 mins to install I did all by watching video on you tube gave step by step. I have the induction system and I love it!
Discussion Starter · #4 ·
thanks for the info i appreciate it, ups just delivered it today so ill install it this weekend. thanks again guys :smileup:
you don't have to reset if you don't want...the pcm will adapt after some miles are put on...the harder you drive, the more aggressive the pcm will set the tables..
Hi
I also installed it myself. Took about 30 minutes.
I didn't disconnect the battery. Don't see a see need to do that.
There's one thing I wasn't expecting: the noise level. At even moderate throttle levels the noise is really obvious. My wife hates it a lot and begs me to get rid of it.
It does improve throttle response and overall power but beware of the intake noise.
I agree with the intake noise but you can make it louder or quieter depending on your right foot. With a bit of practice you will be able to control the noise when you want to but also make it loud when you want to. I put mine in about a year ago, no regrets at all.
u really get very little gains with just an intake i bougth mine cause i love sound of it breathing sounds super nice in that 2500 to 3500 rpm range
I just installed a K&N cold air kit today on my 2011. Definite difference in the sound from the engine compartment, but thats a good thing.
Mike
Think you found enough help but I think I know why they say disconnect the battery. I was out in my driveway the other day and noticed my neighbors hood up with him under it. No big deal. About 2 minutes later I hear a loud pop. Who knew that batteries don't like dropped tools. He didn't.
1 - 12 of 12 Posts
