1 - 1 of 1 Posts
My engine would start all by itself sometimes; it would run for a few seconds, sometimes for longer. Other times the truck would beep every few seconds for no reason at all. So I dismantled the fobs, and found black residue on the contacts, and one contact disc was loose; cleaned everything good with contact cleaner, reglued the smal disc with silicone rubber, and it's been good since.
Note: if you dismantle the fob, make sure to press hard enough on the tiny Phillip's head; it's hard to get moving, and you don't want to slip; you'll need a jeweller's screwdriver.
1 - 1 of 1 Posts
