1 - 5 of 5 Posts
Discussion Starter · #2 ·
when I received my new remote today it came with these instructions:
2005 Dodge Ram
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
1. Enter your vehicle and close all doors.
2. Fasten your seat belt ( fastening the seat belt will cancel any chiming that may
confuse you during this programming procedure.)
3. Place key into the ignition.
4. Turn the ignition to the ON position ( DO NOT START THE ENGINE )
5. Press and hold the UNLOCK button on a working remote.
6. Continue to hold the UNLOCK button, wait at least 4 seconds, but no longer than
10 seconds, then press and hold PANIC button.
7. When a single chime is heard, release both buttons. The chime indicates the system
is in program mode.
8. Press and release both the LOCK and UNLOCK buttons, simultaneoulsly on the remote
to be programmed.
9. A single chime will be heard. The chime indicates the the remote was recognized.
10. Within 4 seconds of hearing the chime, press and release any button on the remote
being programmed.
11. A single chime will be heard The chime indicates the remote has been programmed.
12. Repeat steps 8 to 11 for a total of 4 remotes.
13. Turn the ignition to the OFF position or wait 60 seconds to exit program mode.
These instructions worked like a charm
Premium Member
I am glad that you got it working
I had a Remote Key issue not too long back, on my 2009
I had one working FOB & had temporarily misplaced my spare FOB
I went to the dealership & purchased a 2nd FOB
The Parts Dept. ordered one & handed me a receipt, on it it had my VIN # & a Alphanumeric CODE.
When the new FOB came in, i took it to the Service Dept, along with the receipt. A Service Writer took a hand held computer to my Ram, plugged it in to my Ram & the computer asked for my VIN & then the Code, it was accepted & i had 2 working FOBs. Three days later i found my missing FOB, now i have 3
:LOL:
Ok so I bought my 94 Hemi Sport used and it didn't come with a fob. Bought a fob and but can't get to program mode. I am trying to ground pin one to pin 4 however there is not a wire connected to pin one. So now I'm wondering if this truck even came with remote opener. Would dodge make a truck with only one key lock on drivers door making it impossible to open passenger door for someone???
You have a '94 hemi? If it only has a keyhole on the driver side, then it is equipped (or at least should be) for keyless entry.
1 - 5 of 5 Posts
