1 - 5 of 5 Posts
I would like to run LED strip lighting under the rails of my bed to light up the cargo area and I see that the lighting comes in different lengths. I want to do the 2 side rails and the cab rail. Should I use 3 individual strips or is it possible to use just one long strip to go around the perimeter? I have never worked with the stuff so I don't know how flexible it is and if I can make turns with it very easily. Any thoughts?
I picked up the strip lighting from suberbrightleds. They sell a waterproof version.
For the lengths you need you should look at a single length. Mine is marked at every 3 led's. If you are going to run it on the three sides of the bed you will need to cut it and start again. You can also get premade corners that make 90deg turns easy.
mikeski
Discussion Starter · #4 ·
Thanks, good information. I didn't know they made "elbows" for it.
1 - 5 of 5 Posts
