1 - 4 of 4 Posts
i installed led bulbs on everything possible. for the front turn signals, i also added the 6ohm 50watt resistors to each side of the truck. when i turn on either turn signal, the opposite side bulb lights at about 20% in sequence with the one that's supposed to be be blinking. suggestions, fixes, referrals? thanks in advance
It only does it with the LED's installed? I would check the combination switch mentioned earlier, i would remove the LED's put the originals back in and see if it still does it. If it does then its probably the switch, if it doesnt do it with the Originals, then remove your resistors and try... yes it will Hyperflash, but atleast you will be able to determine if the Resistors are causing some interference somehow. If it no longer does it with the resistors removed then I would buy different resistors, or use one of these:
http://cgi.ebay.ca/3-PIN-ELECTRONIC...r_Truck_Parts_Accessories&hash=item3363afff38
1 - 4 of 4 Posts
