1 - 16 of 16 Posts
So im getting a 2.5 inch ready lift kit installed next week but need opinion on tire sizes and brands. im thinking 305/55/20 yes using the stock wheels. and between Falken High Countrys and Nitto Terra Grapplers. i guess what im asking is has anyone ran the falkens, ive never really heard of them? will they stick out too far or rub? will i need spacers? im a newbie give me a break! lol
Any respose will help.
I wish I was helping you but I am in the same scenario and hope to see some replies soon. I want a tire that performs well on street with a little bit of attitude in appearance.
From what I have seen Falken has great customer service and a good warranty... they shouldnt stick out very far and shouldnt rub. theres a few members running a level with 305/55/20, platinuminjected is a member I can think of off the top of my head, maybe search for him and post a question on his profile page and ask him how his are...
Nitto mud grapplers excellant tire good traction and they look good aswell
I hate to throw in extra confusion but I'm not so sure you can run a 305 wide tire without 1/4" spacers. I know you cannot run that wide on an 06-08 truck without them and I thought the fourth gens were the same. This is a fairly common topic so I am sure there is an answer somewhere. I'm pretty sure a 1/4" spacer would be enough if one is required. That's not really a big deal but you should really do your homework on spacers and know what you are getting into if that's the route you end up taking.
Have you considered a 275/65/20? Taller than stock (and taller than the 305/55) but no wider. Helps fill in the extra space created by the level. You could also run a 285/60/20 or a 285/65/20 but those two sizes are extremely limited to tires available and also very expensive.
Id suggest something a little narrower and taller as well I like the 285/60/20 that starquest suggested i have 285/60/18 terra grapplers now on a stock suspension and they just bearly stick out past the wheelwells. Yours will be a little taller since you have the 20" wheels so that will help fill the gap that the level creates.
i dont know if this will help or not but im running a 35 12.50 18 nitto mud grappler and they fit my 08 before i lifted my truck. at that time i only had a 1.5 inch leveling kit.
I bet they fit because your aftermarket rims have less backspacing than the stockers.
I purchased the Nitto Terra Grapplers today. 275/60/20. Dealer let me try a 305/55/20 in another brand to show me it would rub and it did. They will be installed Saturday.
Same here. The 305/55/20 terra graps looked great under my 11 sport with 5100s, but they rubbed the upper control arm so i went 275/60. Oh, new rims next time. :doh:
Stock 20's I believe have a +19.05mm 0ffset and will def rub. Personal experience....Bought XD Hoss wheels with a +18mm offset and tried 295x60x20 Nitto Terras which ultimately rubbed the upper control arm!
Gonna get 275x65x20 which should be fine. Looks like u need a zero or negative offset. Anybody need brand new Terras?? :)
these are 305s? I would like them but Im only getting a 1.5" lift on my 2wd 2010 ram. Im using stock rims, if they didnt rub i'd strongly conisder it!
ramrig, if you were closer to VA, I'd think about tryin to get the tires off you.
Leveling Kit Questions?
I have been wanting to level my 4X2 2012 Dodge Ram 1500. Line-x of San Antonio offers a 2.5 inch daystar coil spacer that for the front end. I have seen pictures so I know that it will give it that better leveled look and I plan on getting a little bigger/wider tires after the installation. My main reason for doing this is because i thought it might redistibute the weight a litttle more towards the back wheels and tires. I slip way to much as it is with giving it just a little push and i was hoping this might help. The guy from line-x said he dosn't think it will help performance wise in the way or distibuting some weight to the back. He said its just looks and can get a tire size or two up.. So now I'm not so sure it is worth the 350$ that they were going to charge for everything inc parts labor and alignment. Any ideas because to me I don't see how it won't redistribute the weight.. but I am no expert on cars & trucks either. Please let me know what yall think!!
1 - 16 of 16 Posts
