1 - 7 of 7 Posts
Wondering if anyone has suggestions on a leveling kit for my 2013 4X4 Big Horn. Looked at rough country 2.5" kit and bilstien shock kit. Basically wasn't sure if I should go with spacers or the shock kit. :4-dontknow:
FYI - There are some upper control arm/ball joint issues with 2013+ trucks when using leveling kits. Some guys are also seeing the same problems with shock levels, but they seem less frequent then the leveling kits.
Discussion Starter · #6 ·
Yeah, I knew that didn't sound right. Thanks for the help, the link was really helpful. I'll probably go with bilstein. Don't do much rough terrain, but the sounds like the shocks are the safer option and leave more room to add stuff later on.
Don't go with the RCX, they are preload spacers and that will change the spring rate giving you a stiffer ride. There are better kits out there, look for one that gives you strut extensions.
I have read nothing but good things about the bilistens.
1 - 7 of 7 Posts
