Levelling Help
734 5
I have a TRX will Bilsteins work to level it? I have only read about a different strut attachment point. Looking for any advice!!!
1 - 6 of 6 Posts
2017 Ram Rebel 5.7L Flame Red
Discussion Starter · #4 ·
Thanks have sent them an email to verify that they will work with the TRX. Does anyone know if the TRX does have a different front strut attachment point over a non TRX?
Discussion Starter · #5 ·
Emailed a local shop and this is what they came back to me with
"Hi Shawn,
Yes you are correct that the trx4 trucks have a different front suspension then the others. There is really only one good way to lift the front of those trucks. That is with the bilstein 5100 series height adjustable strut. Basically the factory trx4 strut is .7" taller then a stock strut so if you try to put a level kit spacer in it over extends everything and can lead to vibrations and other issues. The bilstein strut replaces the longer factory strut and gains about 2" over stock height. "
5100's as some suggested seems to be the way to go
1 - 6 of 6 Posts
