1 - 6 of 6 Posts
So far all I can find are the smitty built and the RBP bars that mount thru the front bumper.....
Not sure these can be used with tow hooks or not....
Anyone have large offroad lights on their '12?
I am looking for a method where I can remove later leaving no damage.
Thinking a stake-pocket mounted sport bar might be the cat's meow.....get the lights up high.......anyone have one?
Discussion Starter · #5 ·
Looks good, though I was hoping to go a little higher than that......
So, its just a bolt thru each plate hole? Seems like a lot of weight for two bolts to hold?
How stead is the light in off road situations...do they bounce a lot???
I'd like it higher too but that's the compromise I had to make in order to avoid drilling and keep the tow hooks. The bar is mounted pretty solid with 2 3/8" bolts, I'm not worried about it's durability. I haven't noticed any bounce that I could attribute directly to the light bar on logging roads. Lightforce makes a very lightweight unit, but I can't imagine that would change with a heavier light.
1 - 6 of 6 Posts
