1 - 2 of 2 Posts
His truck is a 1st gen 91 d 150 dodge ram 2wd w 318 w/fuel injection....it wont start and when it does start it will just die and wont restart...seems to happen when accelerating. I put plugs,wires new cap and rotor not to mention also repaced the main coil. It isnt getting voltage to the coil!
I do not think that year had a crank sensor. You can try the key trick to get your codes. Key on/off/on/off/on then watch the dash (I think it is the odometer area that blinks). It will blink a code/codes to tell you what is wrong. I can't remember all the codes but you can google search and find them.
1 - 2 of 2 Posts
