I took the shift tower apart to examine it today. It definitely looks different from the pictures on the listings for 94-97.
The numbers I found on it weren't of any help.
According to
moparpartsgiant.com the part number for it should be 5003211AA, but all the listings I find for that part number look different than what's on my truck. Notably the housing is shorter and ball end looks a little different, too. It's also insanely expensive compared to the 94-97 version 😕
What's worse is after dissembling shift tower, I'm not sure it's the culprit of my symptoms as the bushings don't look worn and it seems pretty tight.
I suppose I should have led with the problem I'm having... Sometimes it's hard to get into gear. Almost as if the shifter doesn't have quite enough throw. 1-3-5 are the worst. 2-4-R are less troublesome.
Anyone have any suggestions?
