1 - 5 of 5 Posts
Hi everybody,
I own a 2017 bighorn crew cab short box with an 8 speed and auto 4x4. My questions is how can I find out if it is a 392 diff? Also I would like to find an lsd diff front and rear if possible or what is on the market and available for me.
Try this. It should list all the factory options your truck came with.
2014 Ram 1500 Express 5.7 8Spd
it will list front diff ratio and then rear diff then what type of diff is in the axle:
215MM Front Axle
3.21 Rear Axle Ratio
235MM REAR AXLE
Conventional Differential Frt Axle
Conventional Differential Rear Axle
also i will bet money that its a 321, the steep gear for the 8 spds is a 3.55 and was only put in if you got the option
and as for limited slip or gear options for the front, well were hosed, nobody makes anything for the fronts that i know of and you can either go oem or Detroit true track for the rear
1 - 5 of 5 Posts
