1 - 20 of 25 Posts
I'm in the same boat. The local shop here wants to use a magna flow tru-x muffler DI/DO making a true dual setup. I don't think its that popular on the forum. My main concern is yours: I want a deep tone but minimal in cab drone. I am really leaning towards the magna flow #16869, which replaces the factory with a 22" magna flow SI/DO and all of the piping after including new 5" tips which look really good. It also gets rid of the factory resonators but I think the new tips have them built in. Good luck, hopefully we can both get some help.
Discussion Starter · #3 ·
Yea these exhaust places know exhaust in general but id rather trust the forum where we actually drive and deal with our specific truck daily u know. Good luck and keep me posted on any progress. Now help us people:smiley_thumbs_up:
Btw 5"tips do look great ill eventually buy them separate
I have (IMHO) the perfect balance of power/torque and sound across the entire RPM range,
a nice low rumble at idle that doesn't drone in the cab on the highway,
a Very healthy Hemi Growl at wide open throttle,
...no more resonators, finished off with the gorgeous 5" double walled polished stainless steel tips.
JBA Silver Ceramic Coated Shorty Headers.
Magnaflow Y pipe welded in with mandrel bent stainless steel elbows.
Magnaflow 16869 CatBack w/ 22" muffler (for 4G Hemi with bumper cut-out)
If I had to do it all over again I wouldnt change a thing :smiley_thumbs_up:
Keep in mind muffler shops lose money to those that DIY CatBack bolt-in systems.
They make their money on selling custom dual conversions ;)
I got my DOD14M which is basically just a Magnaflow 14" with the proper pipes already welded on to allow for a 30min install right at home the kit comes from Mufflex and I got mine on within the 30mins no problem and in all honesty I have a 2012 with factory duals and the resonators are still on and they are staying on it is plenty plenty loud the rumble is intense when accelerating and on the highway it's still got rumble but my kids in the back and my wife have no issues with it at all
BUT!!! one suggestion would be to get in the habit of doing the mds disable trick I do it every time I drive the truck and it's easy, all you do is as your leaving the driveway put it in manual mode with the +- put it in 5th and hold both the +- at the same time quickly and it will go into 6th and the 6 will stay on the screen the whole time
But it shifts through all gears problem free and everything works just the same however it won't go into ECO mode and in ECO mode you get drone like a SOB so that's the way to keep it from happening
Also for the records with my truck I was getting 16.3-16.7 AVG now keeping it OUT of ECO mode im getting 17.3-17.5 AVG and have seen it in the 20's from time to time
Discussion Starter · #6 ·
Awesome thanks for the tips pal, im going on monday to the shop im definately doing the ypipe, and muffler then if im not happy I could always go back and remove the resonators, thanks for your help I will keep u guys posted.
The guy doesn't know what he's talking about.
Replacing the y pipe will provide better flow and more power. Also, you will not lose low end torque, don't believe this when people tell you this. I explain why probably at least once a week on here....I need to just save the response so I can copy paste it. If you're really interested why I'll explain it but otherwise you can just believe me.
Removing the resonators has no real benefit. It may unleash a little noise, but won't effect performance and flow. I'd leave the resonators, they help cut drone and resonating.
i have the mufflex 24" i a had my resonator removed just before ive put the muffler on
i dont have a big drone
when i deleted the resonator i did notice a difference in sound but it hard to says if i like it better or not
Just go to another shop. The reason they don't want to replace the stock Y pipe is that they have to custom bend and fit it too the truck. Go ahead and get it changed. I have the 14 magnaflow and the Y pipe and it's not too loud nice growl under throttle and quiet for the cruise. I left the resonators on have very little drone.
Discussion Starter · #10 ·
Lol I just finished reading a lot of your responses on other threads I understand so I wont make you go through all that again lol but I think im going to find another shop, it sucks because thats the only one shop I found that has stainless,id hate to put cheap piping when the truck comes with stainless from factory correct me if I'm wrong. I haven't heard anyone else talk about what kind of piping they got welded on maybe they don't know or maybe im over doing it, let me know thanks
all he had to do was cut the old Y out and he would know what we are all talking about... do it like you want to do it..that sounds good to me..
Just had my exhaust ran with a DI/DO Magnaflow 14in and you can hear it just idling off and when you open it up it's loud. As far as cruising you can hear it but the radio at like 12 all but drowns it out. The shop ran 2.25in piping from where the stock Y was back instead of replacing the Y and doing 3in inlet/2.5in outlet like I had planned on doing. I assume I've got the same amount of flow since it's duals but not sure?
Definately noticed a power difference but not sure how much of that is attributed to the JBA headers. Unfortunately I can't give an accurate opinion on noise level for the exhaust since I got it all done at once, but like I said it's loud but not crazy loud. I'll form a better opinion later this week as I drive it more and give you guys an update on noise level.
the di/do is a good replacement for the stock Y..that's a good option besides an aftermarket Y..
I bought and installed the Mufflex 14" kit because, well, I'm lazy and didn't want to pay the muffler shop to weld it in. It's plenty loud (maybe a bit too quiet sometimes) but I am pleased. I think anything shorter than the 22" muffler and you will probably want to leave the resonators on. I have very little drone with MDS on but I am sure it would drive me crazy if I took the resonators off...
I'm pretty sure that's why the Magnaflow system has a 22" muffler and no resonators. And yes the tips are amazing. If I spent another $250 I could have bought the Magnaflow system. Hell, the 5" tips cost that by themselves...
Right after I installed my CatBack I sold my new factory take-offs for $200.
A local Ram owner wanted to convert his si/so to si/do, and already swapped on a sport bumper.
Local exhaust shop quoted him over $450 (muffler, pipe,tips)
So he was pretty happy to cut his cost in half, and was okay with the stock sport muffler.
Win Win all around. He saved a ton,
My entire system with tips for a bit over $300 (net cost)
Discussion Starter · #17 ·
Thanks guys for all your input, I'm headed out to vegas to get married,
once I come back im going to get it installed, ill post pics and let you guys know the outcome
I took my new magnaflow y pipe to 2 muffler shops today,the first guy more or less laughed at me for bothering to do such a thing buy would do it without quoting a price,just see how long it would take and charge accordingly.$100 an hour.the next guy was much nicer about it but would charge a minimum 2.5 hrs @ $93 per. Do we have any dyno #s to see what the gains are for just replacing the y pipe?
1 - 20 of 25 Posts
