Ok, ordered some LED's for the outdoorsman from superbrightleds. Took out and replaced the drivers side map light. Much better. HOWEVER. The map light will only click on if the passenger's side is on. They both work when the done might is switched on, the doors open etc. But switch on the drivers side map light only, and it won't work. Leave it on, and switch on the passenger's side, and the drivers side will com on.
So, disappointed with that, but went ahead and replaced the passenger side bulb out to the led too. Now, both work fine with the dome switch/door, but try to use them as map lights, and now not only does the previous issue still exist, but now, when you switch on a map light they BLINK.
ANYONE have any suggestions here, or clues??:4-dontknow:
FORGOT. Also can hear some feedback in the speakers when i turn the lights on. Fairly odd....
