1 - 3 of 3 Posts
hi, the map lights in my truck arnt working right now. they had no bulbs to start with so didnt work, figured i would swap them out for the led ones and when i instaled them (after poping the fuse) i went to try them and they wouldnt work, i tryed pressing them, nothing, so any sugestions?
get an ohmeter and measure the non power terminal for the fuse to a good chassis ground. if you get low ohms then you have a short to ground on your power wire. Then you have to chase wires and find the short.
Hey, I just changed my map and dome lights to led. Every so often I notice that they don't come on when I open the door. or unlock the vehicle. Has anyone come into this problem before? Any help would be greatly appreciated :)
1 - 3 of 3 Posts
