1 - 13 of 13 Posts
Can't think anything else to do to the truck just got big valve heads and now on 120 shot anything else you guy think of. Check the signature I might be forgetting some
Discussion Starter · #5 ·
Torque converter and upgrade the valve body. will help you get all that power to the tarmac better brother..
Discussion Starter · #10 ·
Pro edge 3200 and spray the piss outta that thing:)
Yea getting a tq conveter soon edge billet I think see what they say
I'd have to agree with a tq converter or go with a supercharger or turbo setup
No turbo or supercharger I just use n2o
The OEM 2500 or even 3500 cooler are the best ones. Little pricier new, but plug and play and work great (I have the 1 ton).
Thank you will get one this week
Torque converter and upgrade the valve body. will help you get all that power to the tarmac better brother..[/QUOTE
I have upgraded valve body on mike l&m tranny sitting in my garage
Anything else other then valve body tq conveter there left?
With all that other stuff, how do you not have a higher stall TC? Also have you upgraded the trans cooler?
I just went from 3.55 open diff to 4.10 LSD and my tranny average heat went from 137-140 degrees to 156-167 degrees. Called the dealer and they said it was normal but said to change the fluid sooner then the recommended maintenance. Are these larger tranny coolers from the dealer?
I would also suggest an electric supercharger and an upgrade to the piston return springs though if you want to make some real power. :LOL:
You are pretty much tapped out unless you dig into the block. Though, a set of drop in forged pistons would allow you to run a much bigger shot and they're a fraction of the cost of a complete rotating assembly.
Discussion Starter · #13 ·
^^ thanks kurtis yea I guess bigger n2o way to go
1 - 13 of 13 Posts
