1 - 18 of 18 Posts
Discussion Starter #1
Hello,
What is the maximum tire size on the factory OEM rims? I have a 2016 Ram Sport 1500 5.7 with black rims. Current tire size is 275 60 20
I just saw a truck with beautiful set of tires 305 55 20 and they look to be mounted on OEM rims... they look great and I want to upgrade without getting new rims.
Thanks for your help!
I put a set of 305-55-20 on my truck. I did go with aftermarket rims 20x9 and was told they would fit on the OEM rims but I wanted different wheels.
Too Bad you aren't closer. I have a set of Cooper Tires for sale only 4,000 miles on them.
Let me know how it goes because once my tires are done thinking of just keeping the OEM wheels for now and getting bigger tires.
This will be my first winter too with a 2 inch wider tread but winter rated A/T tires. The only downgrade I am preparing for is the slushy wet snow hydroplaning. You'll need to be careful with your normal travel speed.
Heavier tire is also a downgrade, but wouldn't be considerable performance detriment .
Some Assembly Required
The max one can safely go on the 20x9 (laramie and up) wheels is 35 x 12.50 x 20. On the 20x8 on the big horn and below, its probably a 285/65/20.
I just put 275/65/20s on my stock wheels. I got BF Goodrich AT Ko2s. they are great on smooth roads but a bit harsh on the war torn roads here in the Seattle area. They have the snowflake and jack the truck up about 1"( No level kit )
Super Moderator
Do you have any pictures of that setup? A fair number of guys do 275/65/20s with a level but not many at stock height
I run that same size, but with Dynapro ATm tires (also have the snowflake/mountain stamp), and no level. I will try and snap a picture this weekend.
275/65-20's will raise the truck 1/2" since the diameter is 1" bigger than stock. I have this size on a stock-suspensioned truck and they fit fine.
Super Moderator
34's on stock suspension.
That looks really good-a bit beefier in a subtle way. Do you have a pic of the whole side of the truck?
I have a 2011 1500 sport with 305/55/20 Mickey Thompson Baja ATZ and changed to Toyo Open Country A/T II 305/55/20.
Original owner plasma cut horrible looking, obviously unblanced 6mm thick steel wheel spacers as tire was rubbing slightly when doing full turn.
As the DY spacers create some vibrations i pulled them but now it rub's always on the inside of the tire on the upper arm.
I will install a 8mm thick wheel spacer to see if this eliminate the rubbing!
305/55/20 may work with the less widest tires of this group or you need a wheel spacer.
Chris
I probably have a 1 inch lift as under the coils are 1-1.5 high red blocks and i have a rancho 9000 xl shocks.
Here's mine, stock suspension with 285/65/20 KO2's. Works out to a 34.5 tall by 11 inch wide tire, no rubbing at all.
1 - 18 of 18 Posts
