1 - 8 of 8 Posts
This K882445 for the 2wd trucks. It looks like it is all I will need to complete the install, correct?
Does anyone have pics of there truck with this kit on it?
I have a '13 Ram 1500 Quad and was looking to do just a level, but it sounds like there are issues on the '13's with the leveling.
thanks,
John
I have it on my reg cab. Mine is the 4.5 spindles with 3" rear springs instead of spacers. Only extra part I would recommend is a Spohn adj panhard(trac bar) if your ocd like me about having the rear dead center. Anytime you raise or lower this works best for little adjustments. No one really noticed but me. Here is the only pic I have i can post on here so far.
Discussion Starter · #5 ·
Thanks guys, both trucks look great.
Firemedic10584, your truck is the way I want to set mine up. We have close to the same truck, different colors, but close. I just got rims recently(using orig. tires until I get some extra cash, but need to look at what I want to do for lift or level before I get the tires also. Also, looking at the bull bar or just a light bar with the LED strip like you have and some other exterior mods. Here is a pic of what it looks like now.
Also where in Central FL are you located? I am near UCF.
Thanks for the input guys.
Those rims look good! Are you gonna do the maxtrac lift? I think the bull bar and LED bar would look good once you lift it. The LED strips under the door you can do now. That's 20$ mod. The lights are 14$ off ebay and you just need some good 3M double sided tape.
1 - 8 of 8 Posts
