Here are a few videos of my T409 Stainless exhaust. I almost went with the higher grade stainless, however this was cheaper and still offers the lifetime warranty, so if and when it rusts, I'll just have them replace it.
Install was a pain in the you know what. Stock brackets were very rusty and the pipes were VERY hard to get off. A few of them I had to cut slits in with a dremel just to loosen them up enough to slide the stock exhaust pipes off.
Another note, if you have a Crew Cab with the 5 foot bed, you'll have to cut one of the stainless pipes down from 31" to 23" since the bed is shorter. I was unaware and unprepaired for this, however I dug out a cutting wheel and was able to make quick work of it. If you don't wish to do that, you may line up someone else to cut it for you or look at another system.
The drivers side rear exhaust is loose and upon closer inspection, there is a stock rubber bracket that is meant to have a hanger in it to shore everything up. This is about where the last section of pipe bends upward over the Transfer case and sits almost against the bottom of the truck bed. They did not inlcude a hanger to use this bracket and their instructions fail to mention this location. I am going to make a call to MBRP and see if they just goofed and didn't realize their was a bracket there. It's very hard to see since it is in an area that doesn't get much light and the bracket is black. Because there is nothing that is mounted there, the exhaust has the tendency to sag when you give a swift tug on it, similar to a bump or something else you'd encounter on the road. For the time, I have the exhaust tied up with a heavy duty zip tie, but that's a temp fix..... this will HAVE to be fixed as I'm not one to jerry rig my truck.
First video is NOT of my truck, but of a stock exhaust.... since I have an S&B CAI installed, you can use this for reference and see if you notice the deeper tone the S&B Provides..... Enjoy!!!
http://youtu.be/KmsKzEE7siw
My Stock Exhaust with the S&B CAI Installed
http://youtu.be/PM50BikL9ys
MBRP Exhaust with the S&B CAI
http://youtu.be/4sC761VhloU
