1 - 2 of 2 Posts
Im getting a lot of roll for having this set up. Seems looser than stock. Nothing is loose or making noise but it def "floats" too much. The drop was on the truck when I got it. My best guess is the bilstein shocks. Does anyone else run these? They are brand new so I was going to leave them installed but have the belltech streets on hand if I need to swap them out. As far as I know, the bilsteins aren't adjustable...? Anything else I should check? Seems to be the same on all 4 corners.
you may wish to consider upgrading your sway bars..
some of the CC's didnt have rears equipped - did yours ?
from factory , there are 4 thickness of rear (or none !) and 2 for front ;
it's a cheap upgrade .. the thickest rear bar was only like 80$ from the dealer.
I installed that with new poly bushings..
mine already had the thick front so I swapped poly bushings onto it.
1 - 2 of 2 Posts
