1 - 10 of 10 Posts
I have a 2013 Ram with the 5.7, and even while traveling over 28 mph on flat terrain... and even with cruise on, the ECO notification never comes on. I also never notice a change in sound or driveability like some say they notice. I just bought it from a dealership last week. Is it possible the previous owner had a tuner and disabled it? I really don't care either way, as I've heard the MDS has a negligible effect on MPG.
It's possible. What's more likely is that it's disabled due to some error in the system.
A scan tool would tell you for sure. Or, a tuner with live data capabilities.
Discussion Starter · #5 ·
Nevermind. After a quick google search (which I should've done before making this thread) I realize the 2013+ Rams can disable the notification. I checked my truck, and it was turned off.
Premium Member
the ECO light coming on, has nothing to due with MDS functioning
you can be in 8 cylinder mode & have the ECO light on
the ECO Light is just telling you that you are driving in the most efficient manner
it is only a FEEL GOOD light
some ppl have connected up a MDS light, that comes on when it kicks into 4 cylinder mode
My MDS seems to have stopped working as well. My check engine light also came on. i checked the codes through my tuner and there is nothing that is related to MDS showing. I can clear the codes and it seems the MDS seems to work afterward. Once the system senses the fault and the light comes back on, the MDS stops working. Any ideas?
If your MDS is activated your ECO light will be on (if you have enabled it in the settings menu) but the eco can be on without the the MDS being activated.
I may be wrong but, if my memory serves me correctly when the check engine light is on the PCM will deactivate the MDS system.
1 - 10 of 10 Posts
