1 - 6 of 6 Posts
Discussion Starter #1
i have a lifted mega cab with dual steering stabalizer and lately when i am at a stop or slow crawl when i turn the wheels more than a 1/4 turn i get a noise that sounds like a piece of metal that is popping... example(sounds like it would when you try to move one thing over another and it catches a bit then pops over it? best way i can think to describe it, checked and topped off steering fluid but it still does it.
any ideas to start figuring it out would be much appreciated
E
Something obviously is catching another component as it slides past.
What I would do is get a friend to turn the wheel while you are under the truck, listening and watching. It may take a while but that's how a tech would approach the problem...a visual inspection for interference.
I know it's the obvious but steering issues is where I would start:
maybe an excessive angle on or a worn steering shaft u-joint,
how about the tie-rod ball joints?
If there is no belt screeching you can probably rule out the power steering pump...
Discussion Starter #4
thanks for the ideas on starting spots, hopin it turns out to be something not HUGE as far as repairs or costs.
take a look at your front axles too. i snapped one last weekend and it was a clunking/ metal on metal sound.
Premium Member
you might also check for a broken shock absorber or spring
it could cause things to be at an improper angle & cause binding
1 - 6 of 6 Posts
