1 - 3 of 3 Posts
Howdy, all. I have 2013 1500, wanted to replace stock mirrors(heat and power only) with a pair that has a built-in spot mirror(moose ears) right side had one connection plug replacement has two. I connected both plugs and mirror seems to work fine, adjustment wise. Relaced drivers side, it as well has two plugs but there is only one connection in the door. I can adjust the right side mirror from the master switch on the door but not the driver's side. Should I not have connected the 2nd plug on the right side?
Thanks in advance.
Mike
Super Moderator
One of the connections is for auto dim (the flow of electricity activates the chromatic fluid and dims the mirror) and the other is for mirror heat.
Discussion Starter · #3 ·
Thanks Thunderhorse. Not aware of any auto-dimming functions. took drivers side mirror off and found styrofoam balls in the black connector, cleaned it up and appears to be working OK.Don't ask about ambient temp sensor:i_rolleyes:
1 - 3 of 3 Posts
