1 - 2 of 2 Posts
Discussion Starter #1
So I recently acquired a 1985 Dodge Ram Custom 100.
But I'm having a couple of small issues, the largest of which is that my horn doesn't work.
I tried looking under the hood to see if maybe the horn itself was missing or simply out of commission.
But nothing jumped out at me. I'm not even 100% sure where the horn is.
So I'm officially open for ideas.
Anyone?
Discussion Starter #2
Okay, so I got it. Turned out to be the fuse panel directly underneath the steering column. Popped in a 20a fuse and the horn worked fine.
On another note, the horn is under the radiator bracket. Its a dual horn system on either side of the grille. To set up a button, go under the driver side floorboard, and run a line parallel to the hood latch cable(Three Philips head screws will remove the plate that holds the cable in place). There should be cable nooses running along the wall, use this to secure your new line.
Voila! And that's all she wrote.
1 - 2 of 2 Posts
