1 - 7 of 7 Posts
Thanks for the add, I’m having some issues with my truck, 2010 1500 5.7. Did a new cam and lifters, did the MDS delete so just a 2500 cam and hellcat lifters. Got it back together and now it won’t start unless I step on the gas sometimes it will back fire (only done that a couple times.) It won’t idle by itself, if I keep it at 1500 rpms it will run. I’ve got misfire code 300 and system lean bank 1 and 2. I pulled the timing cover back off re-did timing still the same. Any ideas any one? This is the timing I went off.
Hi did you ever figure out what went wrong? I just did new cam and lifters in my 2500 and having the exact same problems you are describing.
Has anyone figured it out I did cam swap mds delete I know timing is right stock cam it starts fine idles just for a minute then engine light starts to flash and won’t idle if I hold the rpms around 1200 it runs but getting 0300 code and running rich I’m at a loss
2014 345ci 8hp70 44-44 3.92 Truetrac NX Express Comp Greene Racing
What device are you using to turn off MDS?
also curious what MDS delete kit including cam number.
1 - 7 of 7 Posts
