1 - 2 of 2 Posts
Discussion Starter #1
Okay so once my engine warms up, if i gun it from idle it bogs out. And recently once its warmed up, when i shut it off and within 2 or so hours of restarting it, it will give me issues starting where i have to pump the throttle a bit while cranking and then it sounds cammed for a minute. But then it s fine.
Any ideas or anyone with this issue?? :wow:
Hi V8ram360,
Sounds like a fuel issue. Try running some Fuel injector cleaner through it. Also did you recently fill the tank like just before the problem started? When is the last time the fuel filter was serviced. You might also want to check your fuel pressure to make sure it is up to speck.
The next place to look would the electronics involved with fuel/air mixture TPS MAS etc.
If you are getting any codes that would really be helpful in nailing down the area to investigate.
Good luck getting it sorted.
preachp
1 - 2 of 2 Posts
