1 - 9 of 9 Posts
That is a tough question. Typically with a level 33's. Now with Bilsteins at maz settings you can squeeze 35's but those are typically reserved for at least a 4inch lift. Maybe something between a 33-35 would work.
Maybe someone else can chime in.
All depends on what rim U are using. A negative offset rim should work. I had +18mm offset with 295 series tire (35 inch) and rubbed the UCA. Now do I sell the tires or rims?? Haha! Check the offset of rim.
1 - 9 of 9 Posts
