1 - 2 of 2 Posts
Hi I just traded my 96 jeep for a 94 dodge and it needs a rear end I need help finding one close to bremen ga and need help knowing which years I can check to see if they are the same. My truck is a 1994 Dodge ram 1500 5.9 v8 4x4 pls help
Welcome to the Forum!
As your truck is a 4x4, make sure you get the same gear ratio as currently installed as the front and rear differentials must have matching ratios. As an example, if it currently has 3.55 gears, the replacement must have 3.55 gears.
1 - 2 of 2 Posts
