Ouch, this sucks. Honestly I think you would be better off trading in the truck vs trying to undo the lift. I'm pretty certain there was some cutting involved in order for the diff to clear the frame with the diff drop. I believe the rear crossmember is discarded as part of the lift as well. You would need that crossmember along with the cut portion of the frame (drivers side lower control arm mount on aft end) welded back on to be safe.I have a ProComp 6" lift with 35" tires that I unfortunately have to remove for a new job so my truck can fit into the parking garage. Looking for suggestions for removal or perhaps swap with someone with stock 2011 4x4 suspension, rims & tires.
:doh:
